Rotate Annotation Tag
Hi - I just stumbled on this post some great posts on placing tags using the Archi-Lab packages which is great. I am now however trying to control whether the tag is vertical or horizontal (which is not a rotation of a family which I tried with the archi-lab rotate package already) but is based on the revit space bar -> flip function.
Has anyone managed to set the orientation of an annotation tag to vertical/horizontal already with Dynamo?
Hi David,
To set Orientation of annotation tag you need to feed “Integer” value. Parameter storage type is an integer. See example below:
Amazing Kulkul. That’s so simple I hadn’t considered that the orientation was a parameter of the object under the hood. Next time I’ll double check that by getting all element parameters in Dynamo to see what parameters I can play with!
