Wall Orientation and Rhythm and Clockwork packages
Hello all,
Before the holiday break I used a graph that I have used for years to assign a value to a shared parameter to walls to report their orientation. I am currently using Revit 2019, Dynamo 2.02, Clockwork 2.1.2 and Rhythm 2017.11.6.
As you can see in the screenshot, everything works fine until it gets to the Rhythm Node “Wall.NorthSouthEastWest” and the values returned are “null”
Can anyone explain what is happening at this point and how to fix it?
Can you screenshot again but with a few more outputs shown?
I’d like to know what the AllElementsofCategory output is before interrogating that Wall sorting node.
Hm, I’m on a newer version of Rhythm which no longer has this node.
Can you open up the NorthSouthEastWest node and screenshot?
The newer version has a replacement node that’s way better FWIW.
Which version of Rhythm are you using and what is the replacement node?
