- Please why Wall orientation node display null results here?
- Can we get the orientation Nord WS or ouest instead of the cordinnation of the wall Normal vector ?
thank you!
- Try Archi-lab package instead:
- N, S, E, W orientation is relative to where your north is. Try measuring an angle to North and you can work out the direction that way.
Revit 2016 and Dynamo 0.9.2 is the last version that this was tested on. What versions are you on?
i have both 1.0 and 0.9.2 but i test this in 1.0
try 0.9.2 and report back. could be that its a bug in 1.0
Can you first try uninstalling custom node and then reinstall. If it doesnât work uninstall all the packages and install only custom package (archi-lab).
Or else just Calculate the Vector of the element
http://www.mathsisfun.com/algebra/vector-calculator.html
y = N
x=E
-y=S
-x=W
@Kulkul I uninstaled all the packages⌠i even uninstaled Dynamo its self than i instal it ⌠but still displaying NULL ⌠Why ??
please tell me also if Dynamo is more stable in Revit 2017 thus i 'will instal it instead of using 2016
thanks
As you can see @Kulkul
, i uninstalled all the custom nodes but it still display NULL!! the problem is not only with this node for example " find wall Material area" has the same problem !!! why !!?iâm testing dynamo capability (schedeling, extracting element parameter ectâŚ) cause in have a huge work to do with it and iâm fraid to face these kind of problem
so please what is the issue with my dynamo
Did you try above using âRhythm Packageâ node?
Python Script turned yellow using the code that you gave me
clr.AddReference(âRevitAPIâ)
clr.AddReference(âRevitAPINodesâ)
wallinstances = UnwarpElement(IN[0])
vectorlist = list()
for item in wallinstances:
try:
vectorlist.append(item.Orientation.ToVector())
except:
vectorlist.append(list())
OUT = vectorlist
Sorry i have No background in programin
Hi @segatakieddine ,
I have an alternative node , the code is slightly different but does the exact same thing⌠It gets te orientation of all types of revit element. Itâs in my package Node-Mode . If you donât want to download the package for so little hereâs the code:
clr.AddReference(âRevitNodesâ)
dataEnteringNode = IN
elements =
for i in IN[0]:
elements.append(UnwrapElement(i))
vectors =
for e in elements:
vectors.append(e.Orientation.ToVector())
OUT = vectors
Iâm trying to work with your recomendation, but I get this error:
Iâm working with Revit 2016 and Dynamo 1.2.1.
Thanks in advance.
hi i donât find the node âWall.NorthSouthEastWestâ in Rhythm package. Why??
@matarresemarianna Thatâs old node might have been depriciated. Here is the custom node from Rhythm package which your looking for Wall.NorthSouthEastWest.dyf (11.9 KB)
thank you
