I tried to Wall finishes by Room node of Modelical package, but when i play it, it is not which i look forward. Wall finish is not created. Can you help me this issue? Thanks
Hi @D.JohnWick
Could you show us the output?
@D.JohnWick, there’s another script that creates wall finishes by rooms: https://learndynamo.com/mod4/
You mean this
@D.JohnWick Show watch node after Wall Finishes by Room.
t try to run this node but it is not work. what is this problem?
This may be an obvious question, but do you have Rooms in the model? The all elements of category node is reporting null which is your first problem.
i can’t use this node.
Wall Finishes by Room.dyn (3.1 KB)
Wall finishes by Room.rvt (1.7 MB)
up
Here is the video that Modelical provided to their method and custom node. https://www.modelical.com/en/wall-finishes-by-room-modelical-package/ . Hope it will help you.
above node is modelical’s pakage. I used but it is not working. I need explain about this problem. thanks for your idea.
Could everyone help me?
@D.JohnWick, have you tried another script that I was previously talking about? (download link @ learndynamo)
@D.JohnWick, it worked fine with basic project, but is not suitable to use with our office standards, so we don’t use it on a daily basis. Check your inputs - you may have missed to change the room name:
Hi @zhukoven I changed the room name correspond my model but it is missed. I don’t understand basic project. T think using basic project
@D.JohnWick, I mean “rac_basic_sample_project” that comes with Revit installer. What Dynamo version do you use?
@zhukoven I use Dynamo 1.3.1 ?
