Wall Dimension - Extra Dimension
Could any of you smart fellows tell me how to adjust the graph so I don’t get the dimension overlapping the wall? also, I’m trying to get the thickness of the wall dimension as well.
Thank you!
Dim Walls.dyn (46.8 KB)
I am not 100% because I have been able to get my computer open and test, but I think it is because your getting two references per wall, and thus two dimensions.
Try removing one set of references and see if you get just one dim per wall.
I was able to remove one dimension. Now I’m working on removing the 0’-0" and adding the thickness of the walls.
I wish the python script from this post would work but so far, no luck.
What errors are you getting with the Python version? Does it have to do with DisplayUnitType?
I’m not getting an error, it just doesn’t create the dimensions.
Capture
