Wall chamfer
Hi Team,
I’m trying to automate some chamfers to my walls in Revit. Manually, Even with a family, it takes too much time.
I started to use the Genius Loci package, but I’m still stuck. I think I’m doing something wrong,
I want to apply a chamfer to the 4 vertical edges of the wall.
Any advice on what I am doing wrong?
Cheers
better luck with this one from Data-Shapes. i think the first pin was called “Walls” not “input”, in case it confuses u.
Hi @BimAmbit,
Thanks for the comment, still not getting there.
i didnt thought something simple was going to be a battle.
Cheers
Hi @break113 try open the node and rename input to walls e.g, and seems you dont input a cornice or reveal element type…
Hi @sovitek,
im no getting there i figure out the issue, and is the family a line based family only can be sorted in horizontal and not vertical
yeah my example was only if you want use datashapes wallsweep tool as @BimAmbit suggest…anyway seems you use a linebased family and could work as well., with that node you already use, if you want you could share that linebased family and we could take a look
Yes, please. Here are the files. Thanks for looking.
15X15 SUPER CHAMFER PROFILE.rfa (416 KB)
CHAMFER BETA.dyn (12.4 KB)
thanks…yeah thats a 2d profile family, try open the family and set it to wallsweep as i assume you want and then try datashapes wallsweep node…something here maybe..
Hi, @sovitek
For some reason its not working for me hehe..
Thanks fors the screenshot
If you are in 23-24 be sure you have dynamoironpython package 2.7 version 2.5 installed as well
i am using revit 2025, but i installed python 2.7
arhh then use 2.7 version 3.2.1
Its updated and still null… LOL
allright and you have removed the 2.5 python package ? and when i look at your image you feed in a reveal but in the node you have reveal set to false try set it to true…cant test in the moment, but if i remember it could run with ironpython3 and cpython3 as well so try that and see if it could be better and be sure you have the latest datashapes package installed
Hi, here’s a possibility.
It’s definitely still improvable. I’ve taken into account common connections (no chamfers).
Here’s the script and family.
Code Python + script + family
Python 1: Determine the longest vertical edges
import sys
lines=IN[0]
#Found the lines with vector Z
a=[l for l in lines if l.Direction.Normalized().Z!=0]
#Found the lines biggest
b=[l for l in a if l.Length == max([l.Length for l in a])]
OUT = b
Python 2 :Keep the edges where the chamfers must be applied
import sys
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import XYZ,Outline,FilteredElementCollector,BoundingBoxIntersectsFilter,Wall
pts=IN[0]
rep=[]
for p in pts:
    #Create outline to intersect element
    p1=p.ToRevitType()
    pb=XYZ(p1.X-0.01/0.3048,p1.Y-0.01/0.3048,p1.Z)
    pe=XYZ(p1.X+0.01/0.3048,p1.Y+0.01/0.3048,p1.Z)
    ol=Outline(pb,pe)
    filter=BoundingBoxIntersectsFilter(ol)
    le=FilteredElementCollector(doc).OfClass(Wall).WherePasses(filter).ToElements()
    rep.append(len(le)<=1)
OUT = rep
Python 3 : Cut the walls with the chamfers and mask them
import sys
import System
from Autodesk.Revit.DB import SolidSolidCutUtils,ElementId
sc=UnwrapElement(IN[0])
w=UnwrapElement(IN[1])
l=List[ElementId]()
doc=sc[0].Document
actv=doc.ActiveView
for s in sc:
    SolidSolidCutUtils.AddCutBetweenSolids(doc,w,s)
    doc.Regenerate()
    l.Add(s.Id)
actv.HideElements(l)
OUT = 0
Script:
essai avec chanfrein sur arete.dyn (64.2 KB)
Family:
chanfrein.rfa (404 KB)
edit: Please take into account Mr. Sovitek’s remarks regarding python versions.
Sincerely,
christian.stan
