By making a script for placing walls I ran into a strange problem. When a Wall.ByCurveAndHeight function is called and a vector is applied the wall will generate on a different level and the data in the properties of the wall don’t match.
The problem doesn’t appear when the same code is made in Python.
Does anyone have an explanation for this?
Code Block:
vectorx = Vector.ByCoordinates(vectorxin,0,0);
x1 = 0;
y1 = 0;
z1 = 0;
x2 = 2000;
y2 = 0;
z2 = 0;
wallheigth;
level;
walltypes;
vectorxin;
StartPunt = Point.ByCoordinates(x1,y1,z1);
EindPunt = Point.ByCoordinates(x2,y2,z2);
EindPuntVec = EindPunt.Add(vectorx);
lijn = Line.ByStartPointEndPoint(StartPunt,EindPuntVec);
Wall.ByCurveAndHeight(lijn,wallheigth,level,walltypes);
Python Code:
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
dataEnteringNode = IN
# Place your code below this line
x1 = IN[0]
y1 = IN[1]
z1 = IN[2]
x2 = IN[3]
y2 = IN[4]
z2 = IN[5]
hoogte = IN[6]
level = IN[7]
walltype = IN[8]
vector = IN[9]
metersToFeet1 = 0.3048
feetToMeters = 1 / metersToFeet1
mmToFeet = feetToMeters/1000
LeveId = UnwrapElement(level).Id
WallTypesId = UnwrapElement(walltype).Id
hoogte = hoogte*mmToFeet
XYZstart = XYZ(x1*mmToFeet,y1*mmToFeet,z1*mmToFeet)
XYZeind = XYZ(x2*mmToFeet,y2*mmToFeet,z2*mmToFeet).Add(XYZ(vector*mmToFeet,0,0))
Curve = Line.CreateBound(XYZstart,XYZeind)
Wall = Wall.Create(doc,Curve,WallTypesId,LeveId,hoogte,0,False,False)
OUT = Wall
Wall test.dyn (24.0 KB)
