Python wall LocationCurve issue
I’m having trouble getting the curve of a wall LocationCurve.
When I try to get the Curve, it gives an error.
What am I doing wrong? I’ve looked at tons of examples where this works.
Ultimately, I’m trying to write a python code to find if a wall is exterior or interior by seeing if there’s a room next to it (based off Domina Package)
clr.AddReference('RevitAPI')
from Revit.Elements import *
app = uiapp.Application
walls = UnwrapElement(IN[0])
for i in range (0,len(walls)):
   wall = walls[i]
   # extract wall geometry and calculate middlepoint
   loc = wall.Location.Curve
OUT = loc
This means that some of the elements under the walls category have most likely been modeled as in-place components. In order to ensure you are only getting actual Wall objects, you can use a FilteredElementCollector like this:
from Autodesk.Revit.DB import FilteredElementCollector, Wall
walls = FilteredElementCollector(doc)\
	.OfClass(Wall)\
	.WhereElementIsNotElementType()
crvs = []
for wall in walls:
	loc = wall.Location
	crvs.append(loc.Curve)
OUT = crvs
What @cgartland has shown is great! It will return the internal Revit Type though and to convert that to the Dynamo one, you have to add in a couple of lines as follows:
  1. Add in the RevitNodes reference and import the GeometryConversion type.
  2. Run a loop (Or in my case, a list comprehension) across the returned internal type curves to change to Dynamo’s
# Import ToProtoType, ToRevitType geometry conversion extension methods
.OfClass(Wall)\
crvs = []
for wall in walls:
    loc = wall.Location
OUT = [c.ToProtoType() for c in crvs]
You can explore what these lines do here: https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration
Thank you,
If I want to further filter the walls by a specific workset, what do I add?
walls = FilteredElementCollector(doc).OfClass(Wall).WhereElementIsNotElementType()
bldgwalls = FilteredWorksetIdIterator(walls).OfClass(0).WhereElementIsNotElementType()
crvs = []
for wall in bldgwalls:
	loc = wall.Location
OUT = crvs
A bit messy but it will do.
walls = FilteredElementCollector(doc).OfClass(Wall).WhereElementIsNotElementType().ToElements()
worksets = FilteredWorksetCollector(doc).OfKind(WorksetKind.UserWorkset)
worksets_name = [i.Name for i in worksets]
worksets_id = [i.Id for i in worksets]
walls_worksets = [i.WorksetId.IntegerValue for i in walls]
worksetname = IN[0]
workset_filtered = []
n = 0
for i in worksets_name:
	for k in worksetname:
		if i == k:
			workset_filtered.append(worksets_id[n].IntegerValue)
	n=n+1
walls_filtered = []
n = 0
for i in walls_worksets:
	for k in workset_filtered:
		if i == k:
			walls_filtered.append(walls[n])
	n=n+1
crvs = []
for wall in walls_filtered:
    loc = wall.Location
Thanks,
Now I’m trying to get the midpoint of the line. It’s giving me a unexpected indention error.
worksetname = ['All Other Elements']
n = 0
		if i == k:
	n=n+1
walls_filtered = []
n = 0
		if i == k:
	n=n+1
midpoints = []
    loc = wall.Location
    Spoint = loc.Curve.GetEndPoint(0)
    Epoint = loc.Curve.GetEndPoint(1)
    Mpoint = Point.ByCoordinates((Spoint.X+Epoint.X)/2,(Spoint.Y+Epoint.Y)/2,(Spoint.Z+Epoint.Z)/2)
	midpoints.append(Mpoint.Points)
OUT = midpoints
You can use the Curve.Evaluate method
https://www.revitapidocs.com/2019/1145f18e-3e01-60df-e438-e176c38c3ce9.htm
try adding
loc = wall.Location
curv = loc.Curve
Mpoint = loc.Evaluate(0.5, False)
Sorry I didn’t see that there was an indentation issue , I copied and pasted into python IDLE and got a mixed tab/spaces alert.
I wish I had an easy solution for this. When I get this I just use IDLE Dedent/indent for each section.
@ckepner It would be kind of you if you’d tell right away what you are trying to achieve instead of adding every time new thing to your requests.
Evaluate method proposed by @jonathan.talisman is indeed the correct way to get the midpoint of a Revit curve. However, your original request is long solved by @cgartland in the second post. Please choose his solution so the topic is closed. If you want more then create a new topic and specify the whole request so that people with same/similar problem can easily find it. Thank you in advance.
