Is there a way to create a wall by profile with curve loops inside the main profile?
I tried the Wall.ByProfile node from the Wombat package, but it just creates a separate wall for each profile (and places them on the same bottom position as well).
You’re right, I tested it on a simple case in a new file and it worked.
In my script however, it would give an error if I tried to feed it a list of flattened curves.
I was able to trace the problem to where I had grouped the curves and joined them into polycurves before joining with another list and exploding them again. For some reason that was causing a problem even though I ended up with seemingly the same curves in the end.
Anyway, I removed that part of the script and it worked perfectly.
Thanks for the pointer!
