Hello to everyone, I’ve been trying to make faces from a .Sat file in mass but I’ve not even been able to going further from select element.face in dynamo, it tells me -Warning: Element.get_Faces operation failed. I think something wrong may be with the mass, But I still not don’t figure it out. I’d appreciate a lot your help
trim_with_edge_loops requires all curves to touch surface-
That´s the model, I can’t upload the file, the website doesn’t allow it to me
https://drive.google.com/file/d/0B2UNJE2We3NlZVZSVFR2c1RFMEE/view?usp=sharing here the link of my file
I am experiencing the same issue, would like to see if anyone has a solution to it.
I did some tests and the only workflow that worked is:
- Import your .sat in a Mass Family
- Load the mass to the project
- Select all the faces with this graph:
The advantage is that you can select all the faces with a big rectangular selection, while in Revit you must pick face by face.
@kevinShen
Or select all faces from the Mass all at once.
Hi Marcel,
This was my initial approach to retrieve element.faces, however, I encountered similar issues with Alexis see image below;
The conceptual mass was selected with SAT file hosted in it.
Luca,
Thanks again for the prompt reply, I will give it a go today to see if its applicable.
I also did the same what you have shown, but it does not work for me, it’s showing NULL
Ref: Image
Kindly give me some solutions
