I’m not getting why Wall.ByFace is returning null.
I think Wall by face only accepts Mass faces as input.
i have imported this geometry as mass in revit
can you try the Clockwork 2.x version of Wall.byFace?
Hi @ROY
@m.rijsmus is right. Wall by Face method requires the face of a mass or generic model element. The surface may be a surface but the host is just as important. Dynamo still has to follow the same rules as Revit.
It doesn’t work like that.
okay i got it. maybe i should work with curves instead of surfaces.
i’ll check if it works.
I’m trying to do the same thing as I want to use Mass objects for space planning and then convert them into walls.
My wall by face node is saying I should be using Mass faces.
Is there a way to select Mass faces rather than get a surfaces list from the mass objects?
Use “Select Faces” node.
Could you drop here rvt file. It will help others who’s trying to help you.
