I think it may be something to do with dependant views? But I cant get the sheet number value for this and some other views on sheets. Anyone know whats up?
whaaaaaaat
@vanman ,
Can you share your revit file?
“Referencing Sheet” input as ParameterName. not Sheet Number
trying to sort a file for ya. Referencing sheet is the wrong information. I want the sheet number. Which is showing in the revit parameter. Dynamos just not pulling it
I cleared out the revit file to send to you with just sheets and views but then it started reporting the sheet number with the file cleared out ![]()
Sorry I think I know what’s happening! The ReferenceCalloutsView node is getting the the main view. Not the the split up dependent view the reference callout is in. Would anyone know how to fix that?
For instance its getting
But it should be getting one of these two views, whichever the reference callout is in
clr.AddReference('RevitAPI')
def GetOwnerView(item):
if hasattr(item, "OwnerViewId"): return item.Document.GetElement(item.OwnerViewId)
else: return None
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetOwnerView(x) for x in items]
else: OUT = GetOwnerView(items)
@Ewan_Opie simple fix by any chance? Had covid this week so only just now been feeling ok to dynamo again
still need to try out your tag all views node
maybe something here
I should think so, will look Monday ![]()
Bugger that for a joke, hope you are properly on the mend.
@vanman Try this one.
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FilteredElementCollector,BuiltInCategory,Viewport, View
## Convert an instance/list to a list
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
else: return None
## Get an Element Parameter
def getParam(element,param):
value = []
try:
DB = element.GetParameters(param)
for i in DB:
if "Double" in str(i.StorageType):
# Metric Converstion
value.append(i.AsDouble()*304.8)
elif "Integer" in str(i.StorageType):
value.append(i.AsInteger())
elif "String" in str(i.StorageType):
value.append(i.AsString())
elemId =i.AsElementId()
value.append(doc.GetElement(elemId))
except:
pass
return value
# Get All Viewports (Views on Sheets)
viewports = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
viewNames = []
viewportIds = []
views = []
viewIds = []
viewRefs = []
# Map Viewports to View Names
for viewport in viewports:
viewId = viewport.ViewId
v = doc.GetElement(viewId)
views.append(v)
viewIds.append(viewId)
viewNames.append(v.Name)
viewportIds.append(viewport.Id)
# Construct Viewport Ref
vpRefNum = str(getParam(v, "Detail Number")[0])
vpRefSheet = str(getParam(v, "Sheet Number")[0])
viewRefs.append(vpRefNum+"-"+vpRefSheet)
# Input views to find which sheet they are placed on
elems = tolist(UnwrapElement(IN[0]))
eOwnerSheets = []
eOwnerViews = []
eViews = []
for e in elems:
# Check if elem is a Viewport
if "Viewport" in str(e.GetType()):
# Get the owner Sheet
eOwnerSheet = GetOwnerView(e)
eOwnerSheets.append(eOwnerSheet)
# Get the associated View
vid = e.Id
vIndex = viewportIds.index(vid)
refView = views[vIndex]
eViews.append(refView)
# Get the Owner View
refViewD = str(getParam(refView, "Referencing Detail")[0])
refViewS = str(getParam(refView, "Referencing Sheet")[0])
find = refViewD+"-"+refViewS
refOwnerIndex = viewRefs.index(find)
refOwner = views[refOwnerIndex]
eOwnerViews.append(refOwner)
# Get the view name
eName = e.Name
# Find the same name in the mapped names/viewports lists
eViewport = viewports[viewNames.index(eName)]
eOwnerSheet = GetOwnerView(eViewport)
vid = e.Id
OUT = eOwnerSheets,eOwnerViews,eViews
Try this and lets see which elements are erroring.
def tolist(obj1):
else: return [obj1]
else: return None
value = []
try:
for i in DB:
except:
pass
return value
viewNames = []
viewportIds = []
views = []
viewIds = []
viewRefs = []
views.append(v)
# Construct Viewpoer Ref
eOwnerSheets = []
eOwnerViews = []
eViews = []
errors = []
for e in elems:
try:
vid = e.Id
except:
# Add the element instead for troubleshooting
errors.append(e)
try:
# Get the view name
eName = e.Name
vid = eViewport.Id
except:
errors.append(e)
OUT = eOwnerSheets,eOwnerViews,eViews,errors
Ah, are most of these were linked views?
yeah unfortunately. To find out where typical details are used in linked projects too. Could be searching through a few projects sometimes. It was working all good till dependent views got thrown into the mix with this one project
Adding references to look in link documents seems to be working, give this a go.
def tolist(obj1):
else: return [obj1]
else: return None
value = []
try:
for i in DB:
except:
pass
return value
# Allow for link docs
linkInst = tolist(IN[1])
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
for l in linkInst:
Ldoc = l.GetLinkDocument()
Lviewports = FilteredElementCollector(Ldoc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
for Lviewport in Lviewports:
LviewId = Lviewport.ViewId
Lv = Ldoc.GetElement(LviewId)
Lviews.append(Lv)
LviewIds.append(LviewId)
LviewNames.append(Lv.Name)
LviewportIds.append(Lviewport.Id)
LvpRefNum = str(getParam(Lv, "Detail Number")[0])
LvpRefSheet = str(getParam(Lv, "Sheet Number")[0])
LviewRefs.append(LvpRefNum+"-"+LvpRefSheet)
viewNames = []
viewportIds = []
views = []
viewIds = []
viewRefs = []
views.append(v)
eOwnerSheets = []
eOwnerViews = []
eViews = []
for e in elems:
try:
# Find view in current document
vid = e.Id
# Get the view name
eName = e.Name
vid = eViewport.Id
except:
# Try to find view in link docs
Lvid = e.Id
LvIndex = LviewportIds.index(Lvid)
LrefView = Lviews[LvIndex]
eViews.append(LrefView)
LrefViewD = str(getParam(LrefView, "Referencing Detail")[0])
LrefViewS = str(getParam(LrefView, "Referencing Sheet")[0])
Lfind = LrefViewD+"-"+LrefViewS
LrefOwnerIndex = LviewRefs.index(Lfind)
LrefOwner = Lviews[LrefOwnerIndex]
eOwnerViews.append(LrefOwner)
# Get the view name
eName = e.Name
eViewport = Lviewports[LviewNames.index(eName)]
Lvid = eViewport.Id
I was hoping you’d give this a go!
I was trying but failing with Genius Loki/clockwork code. Sometimes people didn’t have a project linked in so I used this node that got all links and open documents for them to pick from. So the other projects come through as below. Not sure if there’s a node to get the link instance from something if its just another open document? Or would it be an easy fix?
#Part of script from Clockwork
inputdoc = UnwrapElement(IN[0])
if inputdoc == None:
elif isinstance (inputdoc, RevitLinkInstance) :
doc = inputdoc.GetLinkDocument()
elif isinstance (inputdoc, Document) :
doc = inputdoc
else: doc = None
If you already have a list of LinkDocuments in the project then this part of the code can be adjusted, as this was just converting and loaded LinkInstances to Doc format. Change to the below.
linkDocs = tolist(IN[1])
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
for Ldoc in linkDocs:
