Trying to get Python to give me the #Sheet Number or #SHEET_NUMBER / Name with
VID = view object…
SNUM=VID.get_Parameter(BuiltInParameter.SHEET_NUMBER)
#SNAME=VID.get_ParameterValueByName(BuiltInParameter.SHEET_NAME)
But the darn thing won’t fly. I can get the same effect in a #Codeblock
PY here for quick reference:
# Simplified version by Ron.Allen to just text in views - Apsis0215@gmail.com 2019-01-02
# Deduced from from Konrad K Sobon @arch_laboratory, http://archi-lab.net Get function 2015
# Derived from Jeremy Tammick's bip function work in C#
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
##IN[0] for elements
if isinstance(IN[0], list):
objList = []
for i in IN[0]:
objList.append(UnwrapElement(i))
objList = IN[0]
elements = []
for i in objList:
elements.append(UnwrapElement(i))
##Export values of objects - the TEXT_TEXT built in parameter is the VALUE of the instance of text.
OUT=[]
for obj in objList:
SNUM=""
SNAME=""
VID= None
VName="nil"
PVAL=""
##View ID and Name
if hasattr(obj, "OwnerViewId"):
#Get object View ID
VID=obj.Document.GetElement(obj.OwnerViewId)
#Get Object View Name
Vname=VID.Name
#SNAME=objView ##.get_Parameter(BuiltInParameter.SHEET_NAME).AsString()
##String Valiue of note from BuiltInParameter
PVAL=obj.get_Parameter(BuiltInParameter.TEXT_TEXT).AsString()
##Append values to list
OUT.append((SNUM,SNAME,VID,Vname,PVAL))
I tried similar approaches and kept getting the same result. This post on the Autodesk forums was never fully solved so not sure how to fix it.
If you really need it done in Python, the alternative is to import dynamo nodes into python and use the same flow in your codeblock, as shown below:
# Import RevitAPI
clr.AddReference('RevitAPI')
import System
clr.AddReference('DSCoreNodes') #Imports Dynamo Nodes into Python
from DSCore import *
objList = UnwrapElement(IN[0])
objList = [UnwrapElement(IN[0])]
OUT = []
for obj in objList:
VID = obj.Document.GetElement(obj.OwnerViewId)
Vname = VID.Name
DVID = VID.ToDSType(True)
SNUM = DVID.GetParameterValueByName("Sheet Number")
SNAME = DVID.GetParameterValueByName("Sheet Name")
PVAL = obj.Text
OUT.append((SNUM, SNAME, VID, Vname, PVAL))
I didn’t add in an else condition so you will have to put it in.
Reasonable approximation with Codeblocks to shore up the gaps…
dyn-extract-notes-v00.90.dyn (16.4 KB)
You also need to add the add reference and import for DSCoreNodes, as that allows you to use Dynamo nodes inside Python (using design script syntax).
Working DYN here:
dyn-extract-notes-v00.96.dyn (9.4 KB)
# Simplified version by Ron.Allen to just text in views - Apsis0215 at gmail.com 2019-01-02
clr.AddReference("DSCoreNodes")
# Import RevitAPI
import System
objList = []
for i in IN[0]:
objList = IN[0]
elements = []
for i in objList:
OUT=[]
#OUT.append(("Sheet Number","Sheet Name","DetailID","View Type","View ID","View Name","Text Note","Object GUID","Revit Select ID"))
OUT.append(("Sheet Number","Sheet Name","DetailID","View Type","View Name","Title on Sheet", "Text Note","GUID","RevitID"))
for obj in objList:
SNUM=""
SNAME=""
SDtlID = ""
VType = ""
VID= None
DVID=None
VName="nil"
strTxtVal=""
strViewTitle=""
##View ID and Name
#Get object View ID
Vname=VID.Name
SDtlID = DVID.GetParameterValueByName("Detail Number")
VType = DVID.GetParameterValueByName("Type").Name
strViewTitle = DVID.GetParameterValueByName("Title on Sheet")
strTxtVal=obj.get_Parameter(BuiltInParameter.TEXT_TEXT).AsString()
#Get GUID
objGUID=obj.UniqueId #Get by ID: #obj = doc.GetElement(objGUID);
EleID=obj.Id
#OUT.append((SNUM,SNAME,VID,Vname,strTxtVal))
OUT.append((SNUM, SNAME, SDtlID, VType, Vname, strViewTitle, strTxtVal, objGUID,EleID))
OUT = map(None, *OUT)
Update to PY: *Not sure about the PVAL=Obj,name in the end but… for 2.0:
import Revit ##Import Revit References
if isinstance(IN[0], list): ##For dingle-element list
objList = UnwrapElement(IN[0]) ##Add it to the object list as Revit elements with unwrap
objList = [UnwrapElement(IN[0])] ##Otherwise convert whole list
OUT = [] ##Defin OUT as a list
for obj in objList: ##For each element in the list
if hasattr(obj, "OwnerViewId"): ##IF it has the OwnerViewID attributea
ViewID = obj.Document.GetElement(obj.OwnerViewId) ##Get owner's View's ID
ViewName = ViewID.Name ##Get View's name
DViewID = ViewID.ToDSType(True) ##Convert to dynamo script type for easier handling
SheetNumber = DViewID.GetParameterValueByName("Sheet Number") ##Get sheet number
SheetName = DViewID.GetParameterValueByName("Sheet Name") ##Get sheet name
if hasattr(obj, "Text"):
PVAL = obj.Text ##Get name of object - fails in V2_0
elif hasattr(obj, "Name"):
PVAL=obj.Name
PVAL="n/a"
#Output Position ref.: 00 01 02 03 04
OUT.append((SheetNumber, SheetName, ViewID, ViewName, PVAL)) ##Append values for each item as a sublist
