Thanks, just get left with this error now.
Adjust the code here and get the id of the view in question, then look at the list of viewport ids from the link list, to verify the list structure contains the element.
I get the same error ![]()
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FilteredElementCollector,BuiltInCategory,Viewport, View
## Convert an instance/list to a list
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
def GetOwnerView(item):
if hasattr(item, "OwnerViewId"): return item.Document.GetElement(item.OwnerViewId)
else: return None
## Get an Element Parameter
def getParam(element,param):
value = []
try:
DB = element.GetParameters(param)
for i in DB:
if "Double" in str(i.StorageType):
# Metric Converstion
value.append(i.AsDouble()*304.8)
elif "Integer" in str(i.StorageType):
value.append(i.AsInteger())
elif "String" in str(i.StorageType):
value.append(i.AsString())
elemId =i.AsElementId()
value.append(doc.GetElement(elemId))
except:
pass
return value
# Get All Viewports (Views on Sheets)
# Allow for link docs
linkInst = tolist(IN[1])
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
linkDocs = tolist(IN[1])
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
for Ldoc in linkDocs:
Lviewports = FilteredElementCollector(Ldoc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
# Map Viewports to View Names
for Lviewport in Lviewports:
LviewId = Lviewport.ViewId
Lv = Ldoc.GetElement(LviewId)
Lviews.append(Lv)
LviewIds.append(LviewId)
LviewNames.append(Lv.Name)
LviewportIds.append(Lviewport.Id)
# Construct Viewpoer Ref
LvpRefNum = str(getParam(Lv, "Detail Number")[0])
LvpRefSheet = str(getParam(Lv, "Sheet Number")[0])
LviewRefs.append(LvpRefNum+"-"+LvpRefSheet)
viewports = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
viewNames = []
viewportIds = []
views = []
viewIds = []
viewRefs = []
for viewport in viewports:
viewId = viewport.ViewId
v = doc.GetElement(viewId)
views.append(v)
viewIds.append(viewId)
viewNames.append(v.Name)
viewportIds.append(viewport.Id)
vpRefNum = str(getParam(v, "Detail Number")[0])
vpRefSheet = str(getParam(v, "Sheet Number")[0])
viewRefs.append(vpRefNum+"-"+vpRefSheet)
# Input views to find which sheet they are placed on
elems = tolist(UnwrapElement(IN[0]))
eOwnerSheets = []
eOwnerViews = []
eViews = []
for e in elems:
try:
# Find view in current document
# Check if elem is a Viewport
if "Viewport" in str(e.GetType()):
# Get the owner Sheet
eOwnerSheet = GetOwnerView(e)
eOwnerSheets.append(eOwnerSheet)
# Get the associated View
vid = e.Id
vIndex = viewportIds.index(vid)
refView = views[vIndex]
eViews.append(refView)
# Get the Owner View
refViewD = str(getParam(refView, "Referencing Detail")[0])
refViewS = str(getParam(refView, "Referencing Sheet")[0])
find = refViewD+"-"+refViewS
refOwnerIndex = viewRefs.index(find)
refOwner = views[refOwnerIndex]
eOwnerViews.append(refOwner)
# Get the view name
eName = e.Name
# Find the same name in the mapped names/viewports lists
eViewport = viewports[viewNames.index(eName)]
eOwnerSheet = GetOwnerView(eViewport)
vid = eViewport.Id
except:
# Try to find view in link docs
Lvid = e.Id
LvIndex = LviewportIds.index(Lvid)
LrefView = Lviews[LvIndex]
eViews.append(LrefView)
LrefViewD = str(getParam(LrefView, "Referencing Detail")[0])
LrefViewS = str(getParam(LrefView, "Referencing Sheet")[0])
Lfind = LrefViewD+"-"+LrefViewS
LrefOwnerIndex = LviewRefs.index(Lfind)
LrefOwner = Lviews[LrefOwnerIndex]
eOwnerViews.append(LrefOwner)
# Get the view name
eName = e.Name
eViewport = Lviewports[LviewNames.index(eName)]
Lvid = eViewport.Id
OUT = eOwnerSheets,eOwnerViews,eViews,LviewportIds
opps I shall try be more vigilant ![]()
Think I’ve got it right this time but same error
def tolist(obj1):
else: return [obj1]
else: return None
value = []
try:
for i in DB:
except:
pass
return value
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
LviewNames = []
LviewportIds = []
Lviews = []
LviewIds = []
LviewRefs = []
Lviews.append(Lv)
viewNames = []
viewportIds = []
views = []
viewIds = []
viewRefs = []
views.append(v)
eOwnerSheets = []
eOwnerViews = []
eViews = []
for e in elems:
try:
vid = e.Id
# Get the view name
eName = e.Name
vid = eViewport.Id
except:
Lvid = e.Id
# Get the view name
eName = e.Name
Lvid = eViewport.Id
eViews.append(Lvid)
