hello my dynamo friends,
im trying to get section views from a linked model to the current project. it has worked only its nog on the same location. can anybody help me? can i move a section view of just copy views on the same place.
greetings
Your question is not clear.
Are you trying to get views from linked model? or You want to copy views from linked model?
Im trying to copy views from linked model indeed. Thats working but the problem is that its not copying on the same place. Do u have any clue?
There are many posts related to this query. You can use forum search. Below is one of them:
Awesome… thank you.
Ok.
Your curent document and your linked file do not share the same coordinate system.
There are actually quite a few topics for transforming coordinates from which you can draw inspiration. Once you have found the right vector, you can then use the Element.MoveByVector node to place the newly created sections in the right place.
If you aren’t successful, add to the topic your current document and your linked Revit file so we can help you more effectively.
Hi @Alban_de_Chasteigner , I reproduced the script to copy views from linked file. It works great to copy viewsection line, but it does not copy the views. Am I missing something or something else? could you help me to figure out?
CopyLinkedSectionView.dyn (28.6 KB)
