Views.CreateCallout - trying to create callout views
I am trying to create callout views via Dynamo, all the tutorials and forum posts I found on this subject refer to an Archi-Lab node “Views.CreateCallout” - I installed 2025.300.1225 ver. of the Archi-Lab package that does not seem to contain this node. I searched for this on Search Dynamo BIM Nodes - Dynamo Nodes, Searchable as well and get no search results for the term “callout”.
Is this no longer viable in Revit 2024? Are there any other methods of creating callout views?
Thank you,
Kind Regards,
Mateusz
@Mateusz.Madej
you can install a older archilab version for 2024. or you write your own python code.
@Draxl_Andreas
Thank you for the reply, I will start looking through older versions.
Edit - it worked, the 2024 version had the node I was looking for.
