Hello there,
I was wondering if there is a way to create a callout on a view using Dynamo.
I looked through Dynamo’s built-in nodes, external packages nodes and the API but couldn’t find anything that could be helpful.
Any help is greatly appreciated!
Unfortunately, there is not a built-in node in Dynamo for this, but it seems there is a Revit API here for the callout creation. It requires 2 corner points(min and max point of the callout rectangle) for the callout.
Using Python, you can create a custom node for yourself.
Here is an example Python code:
Python Code for Callout Creation in Dynamo
# Import Revit API
clr.AddReference("RevitAPI")
# Import Revit Services
# Import RevitNodes for geometry conversion
parentViewId = ElementId(IN[0].Id)
viewFamilyTypeId = ElementId(IN[1].Id)
minPoint = IN[2] # Lower-left corner of callout (DesignScript Point)
maxPoint = IN[3] # Upper-right corner of callout (DesignScript Point)
calloutName = IN[4] # Name of the callout view
# Access the current Revit document
# Start a transaction
# Convert DesignScript Points to Revit XYZ
minPointXYZ = minPoint.ToXyz()
maxPointXYZ = maxPoint.ToXyz()
# Create the callout view
callout_view = ViewSection.CreateCallout(
doc,
parentViewId, # View Id that the callout will appear
viewFamilyTypeId, # View Family Type Id for the callout
minPointXYZ, # Lower-left corner
maxPointXYZ # Upper-right corner
# Set properties for the callout view
callout_view.Name = calloutName
# End the transaction
# Output the result
OUT = callout_view
You need to figure out an algorithm to get min and max point of the callout rectangle. After doing this, you can create a custom node for yourself by following these steps:
1- Select the python node
2- Right click on white canvas
3- Select create custom node
4- This will pop up a new window to fill some details. You can write down the details.
5- After that go inside the new custom node by double clicking on the body to edit the input/output names
This shows the inside of the custom node:
This is how it looks in the project:
I hope this will work for you.
I will note that we need a node for this and update you when it is available
FYI: @casandraarmeanu @vlad.catalina
archilab have one as well, we can use too until that
Thank you! That was helpful. For some reason I missed the CreateCallout method in the API docs on revitapidocs.com. When you search for “callout”, these are the results:
There is also another method in the API that is called CreateReferenceCallout. This will create a callout for a view that already exists in the model as opposed to the CreateCallout method that will create a new view (and a callout for it) based on the bounding box supplied. You just need to supply it with the ID of the view that will be referenced by the callout.
