Dear Experts,
I am facing strange problem.
I am adding View Type node from Orchid package. And run script. Everything is working fine at this stage.
However, after closing script (dyn file) and opening same script one more time. I see that the node i recently added changed as screenshot indicates and not working. I need to remove it and add it each time in order make it work normal. And script through Dynamo player not working. What can be reason for that?
Using Orchid134.6.2.7410 package and dynamo 2.13.
Is this a .dll conflict?
Not sure, but Orchid addresses issues on github, youll need to contact him there.
Or you could use an alternate method to select this?
