Hi all,
Both nodes dont seem to work, anyone knows whats going on? Dynamo 2.0.3 with Revit 2019
Do you already have a view with that name? Running both nodes at the same time will definitely give you duplicate names. I would also suggest you close and reopen the graph as dynamo may be saving the duplicate name somewhere.
@Nick_Boyts, thanks for your reply, usualy i use only 1 node. i wanted to show i tried both
It does seem to duplicate but the node doesnt pass the duplicated view through… so after duplicate i wont be able to set parameters etc.
Try running one after the other by freezing the nodes.
@mrathnakar wont help.
did you try with Lacing?
try longest lacing for View.Duplicate !!!
It is duplicating… the problem is that its not giving the duplicated view through.
So basicly i get a duplicate but after that i cant do nothing with it.
View.Duplicate.dyf (7.4 KB)
Try this Node…
i do remember that i have made some changes to it(Python) few months back…!!!
Once try this Node
@Nick_Boyts was allready affraid had to reinstall
