I found this graph on BIM Arena, created it in dynamo 1.3 and it worked a treat! I have since upgraded to 2.0 and the graph runs out a ‘false’. See below the graph.
Any ideas why it is not duplicating the view as dependant? also i have tried ‘view.duplicate’ node and it comes up the same.
When a node is still grey at the top, for example your View.DuplicateAsDependent, that means that it is not running because it is missing an input. I don’t know how earlier versions of that node worked but this one requires you to use a name as the input for it to work.
Another way to tell is that the output of the node is Function, meaning it isn’t doing anything yet.
