Values placed, Preview displaying null
I am a beginner at Dynamo and I have tried following three tutorials but each time I put a value/ select elements, they all come up as null and therefore I am not able to run the script. Is there a settings I need to change etc ? Below is one example
Welcome to the community!
Just to confirm, since you have the graph set to Manual mode, you are clicking the Run button?
yes but it still won’t work, unfortunately
When you run it, does it say Run completed?
I don’t have 2025 installed, so unfortunately I can’t do any testing, but I can’t think of any other reason why it’s not working.
it won’t run at all :frowning:
Oh! My best guess would be an issue caused during the installation or Revit or there is a Revit addin loaded that is conflicting with Dynamo.
possibly, but the only addin that I have is Twinmotion
That’s all I got then. Sorry! Hopefully someone else can provide additional insight.
Thank you for all your help!
Does the ‘normal’ (OOTB) node work?
There should be a + node.
Thank you everyone, it now works :slight_smile:
I tried it out today and that it worked? I am guessing it had something to do with shutting down my laptop ? unsure how this was solved but it works :))))
