Because of crappy search cannot find any topic about this.
The task is to filter a list of elements by a parameter value from a list, not by exact value. The length of the list of possible values varies. Any ideas?
@Nikolay_Gerasimov1 Something like this?
If this doesn’t help, a better description with screenshots would help others understand your problem better
Thanks for the quick reply, looks like it should work, didn’t know that == function works with lists. But:
What’s wrong with this?
@Nikolay_Gerasimov1 Explore Levels by clicking on the arrow besides x and y
Note that I have done so in the example I posted
Ok. Double check - that method works with numbers. With strings things are more interesting:
Suggestions?
@Nikolay_Gerasimov1 The output from Parameter.ParameterByName is not a string
Try changing the level of y (instead of x) will structure the lists differently.
See if the below example helps …
