I’ve been playing around trying to use Dynamo to place Mechanical Families. I’ve tried the clockwork and archi-lab node ‘FamilyInstance.ByPointInView’ and similar, but can only get this to work with detail items, whenever I select a mechanical family I get nothing.
I’ve read as much as I can find on the internet but can’t find anything conclusive saying this is/isn’t possible, so I’m stumped. I don’t want to give it up already if I’m missing something obvious. Has anyone tried this, and if so can anyone point me in the right direction?
However I’m stuck at a stage before that. I can only place certain families using this node, specifically I can’t place Mechanical Equipment. Has anyone succeeded doing that?
@Liam_Alsop What are you trying to place? It would be better if you can show us entire graph of your work or drop some files here. It works from my side. I placed mechanical equipment and it is placing.
Sorry, I tried adding screenshots and was limited to just 1 per post. In this instance I’m trying to place a fan family, yesterday I was trying with a FCU family.
Ok, will do, downloading it now. I currently get this warning running your solution (in 1.1), regardless of the family I use, and whether or not the point coordinates are connected up.
Excuse me for the dumb questione but are you working in a revit project or family?
If you are working in a project could you post a screenshot of the error FamilyInstanec.ByPointAndLevel gives you with these problematic elements? Thanks
I was working in a project, you can see the error in post #9. I was sending a view input into the FamilyInstance.ByPointAndLevel node, when it wanted a level input.
