I have been able to get Dynamo to load Families into a Detail Item (I am running Dynamo in the Detail Item Family).
What I am struggling with is placing families in the view (in this case the Ref. Level floor plan view).
the out of the box node FamilyInstance.ByPoint works, but doesnt make them visible in the view (something to do with them not being 3d geometry based on my research).
Nodes from other packages (like Clockwork and Springs) have nodes that can place families into views by a point but those also seem to fail, even if i hand them only a single view, point, and family type.
Any Ideas on how to get this to run?
I ended up taking the Clockwork Node (FamilyInstance.ByPointInView) pulling it out of the custom node and running it in the main graph with a few edits made with the help of ChatGPT.
not sure if thats bad form, I apologize if it is.
It mostly works, at least it does if i give it a single item or flat list but not if i give it any more than that like a nested list…
Here is what I ended up with:
clr.AddReference('RevitAPI')
# Process inputs
if isinstance(IN[0], list):
points = UnwrapElement(IN[0])
points = [UnwrapElement(IN[0])]
if isinstance(IN[1], list):
famtypes = UnwrapElement(IN[1])
famtypes = [UnwrapElement(IN[1])]
lvl = UnwrapElement(IN[2])
elementlist = []
for point, famtype in zip(points, famtypes):
# make sure familysymbol is active
if not famtype.IsActive:
famtype.Activate()
doc.Regenerate()
if doc.IsFamilyDocument:
newobj = doc.FamilyCreate.NewFamilyInstance(point.ToXyz(),famtype,lvl)
newobj = doc.Create.NewFamilyInstance(point.ToXyz(),famtype,lvl)
elementlist.append(newobj.ToDSType(False))
OUT = elementlist
@Peter.vansteeJS2FV ,
what did you get as a error message?
to correct your syntex:
clr.AddReference('System')
# Process inputs
elementlist = []
famtype.Activate()
doc.Regenerate()
OUT = elementlist
This is the error I’m getting.
File “”, line 35, in
AttributeError: ‘List[object]’ object has no attribute ‘IsActive’
I get the same error with the corrected code that you provided.
than it is not interating correctly…
it has to do like
outlist = []
for f in famtypes:
outlist.append(f.IsActive)
after entirely too much research and trial/error I have something that works
thank you for the help!
elementlist = []
view = UnwrapElement(IN[2])
def NewFamily(point, famtype, view):
newobj = doc.FamilyCreate.NewFamilyInstance(point.ToXyz(), famtype, view)
newobj = doc.Create.NewFamilyInstance(point.ToXyz(), famtype, view)
return newobj.ToDSType(False)
# Process inputs
if isinstance(IN[1], list) == False:
famtype = UnwrapElement(IN[1])
if famtype.IsActive == False:
famtype.Activate()
doc.Regenerate()
point = UnwrapElement(IN[0])
elementlist.append(NewFamily(point, famtype, view))
for i in range(len(IN[0])):
if isinstance(IN[0][i], list) == False:
point = UnwrapElement(IN[0][i])
famtype = UnwrapElement(IN[1][i])
famtype.Activate()
doc.Regenerate()
elementlist.insert(i,[])
for j in range(len(IN[1][i])):
point = UnwrapElement(IN[0][i][j])
famtype = UnwrapElement(IN[1][i][j])
famtype.Activate()
doc.Regenerate()
elementlist[i].append(NewFamily(point, famtype, view))
OUT = elementlist
