Using Dynamo in Family templates
Hi
What family templates does Dynamo work with?
I am trying use Dynamo to create a profile curve. If I use a generic model family template it works, I can place model curves. However, if I use a profile family, I get the error ‘Sketch plane creation is not allowed in this family’.
This could be because profile only use drafting lines and you are using a model cure. Not 100% sure but that would be my first guess
It looks like profile families think of this as a detail line. You also need to convert your line element to a curve (don’t know why).
I will post the Curve.FromLine to Rhythm shortly and the python script is a modification of Clockwork’s DetailLine.FromCurve. So I may submit that as a pull request, and if he doesn’t accept I will post it on Rhythm as well. In the meantime, here is the python script and the .dyf DetailLine.FromCurve
2016-02-17 08_17_57
