Hi everyone.
Dynamo can be create family instance from Geometry Dynamo and Edit sketch line?
Thank Advance!
hi @manhgt214 ,you could edit the family and give it some refplane and parameter dimension then you will have handles…you could probably do it with some BG open not sure…but it will never be model in place
Yes - this can be done. Not easily though. Look into the api and know there are a few steps. Offhand I believe these will get you started, however I haven’t tested in quite awhile:
Thank you!
I will try it, thank a lot!!
