Using Data-Shapes to export Revit Schedule to Excel
I just recently found out about Data-Shapes and wanted to re-do a script I have to export a Revit schedule to Excel.
While I still get my head around data shapes, is it possible to have a dropdown list in the popup which can pick a schedule?
The portion in red is the original script I was using. To make it as simple as possible using Dynamo Player we want a few inputs for Column & Row (which I think I have), file path for excel and a drop down for the schedule.
The later is the bit I’m stuck on, I’ve looked at some of the blog posts but I can’t figure out how to create the drop down referencing a schedule.
—EDIT—
My Dynamo seems to be having an issue and haven’t been able to run the script just yet to see if the colum/row section works.
Yes, you can do that and it is fairly easy. Refer to datashape’s website for more information on how to use his nodes.
I think I can see how it’s done. Correct me if I’m wrong, do I just keep adding to my List.Create for each of the inputs I need?
yup thats basically what you should do, the input nodes should be from data shape as well
I have everything setup except a dropdown list for picking a schedule, I’m not sure how to do this part and I can’t find examples. Anyone got an example of how to do this?
So sorry for the late reply @JoziB, would like to ask if you had solve your own issue already? If you havent, im still willing to help
Yes I got it after I posted. I can’t remember what I did, I probably found it via the data-shapes blog/site.
For anyone looking to do similar!
