Please if you can suggest what’s wrong in the family or you can share the family you used so that I can run the script. Also the attached notification is being displayed about the G Loci package though it is installed. Is it another cause of the issue.
Thanks for the support.
Best Regards,
Bireshwar
What you’re trying to add is a wall span. It’s not the right way to do it.
You need a family file made in void form. In this way, your scenario will work correctly.
Here’s a sample family.
void_sphere.rfa (468 KB)
For this purpose, the package manager released an up-to-date package on March 23. Update your package.
Also, if you continue to have problems with this issue, please start a new topic. @Alban_de_Chasteigner
Hi @SBC and @Durmus_Cesur,
I am now using the latest version of the itextSharp external PDF library which makes this benign notification disappear.
You can update the Genius Loci package and install the latest version : 2021.4.13.
Thank you Durmus, the issues was there with the family. my script running well. Thanks for your support.
Thank you Alban, the notification isn’t coming now.
Best Regards,
Good Evening
However thinking to improve on the same when the link HVAC plan changes, how to fill the previous voids.
Best Regards,
what plugin is this?
You need to check all vs all. Use Cross Product instead of Longest.
Just used search:
Cutting wall with void - Revit - Dynamo (dynamobim.com)
