@Uros - Study the Adaptive Component attached below, it seems to be a little more flexible than the previous ones in this post.
@Mica - The joints are now clean and the definition seems to work most of the time. (Works well for ‘path segment length’ values up to about 40)
Beyond 40, If some segments aren’t created, try tweaking the numbers when calling the function and the ‘path segment length’. Also try with different Nurbs curves.
Dynamo definition: Pathway.dyn
Adaptive Component: path-tile
