Amigo @harry_zhao buenas. when you use the node, FamilyType.ByGeometry you are only making the definition of family type, is like only load the family into the file, you are not creating any instance, you need create instances after, you should use Family instance by point or by point and level in order to create instances of this family type, i let you link to a similar post.
Related topics
| Import Geometry from Dynamo to Revit | 2 | 253 | March 31, 2024 | |
| Convert geometry from dynamo to revit | 26 | 418 | August 22, 2024 | |
| Get a family type by a geometry built into dynamo | 4 | 441 | December 6, 2022 | |
| Exporting Dynamo Generated Geometry into Revit Family | 4 | 1531 | July 1, 2020 | |
| Problem with family instance by geometry - spring node | 10 | 450 | January 15, 2024 |
