Man i have been trying to install dynamo 2.0 in my revit 2017 for days now
1st problem- on dynamobim.org/download , DYNAMO REVIT asks to click a link DYNAMO BUILDS and find the revit versions fo4 2017-2018. But the link shows a list of 3 types of dynamo versions âcoreruntime2.0â âdynamoinstall2.0.exeâ âdynamorevit2.0.exeâ which file do i need here?
2nd problem- when i use Dynamoinstall2.0.exe or dynamorevit2.0.exe, the dynamo in manage tab of revit doesnât have any nodes on the left side. And its just frustrating. I found similar problems with other users on this forum but i swear nothing helped
I so exhausted, i just need data-shapes and its teasing me so much. Please help
As for your nodes disappearing, make sure you did a clean installation on whatever dynamo application is appearing on your control panel, and also if needed, empty all your package directories as well. Then install back the latest 2.0.x build.
If the issue still persist, it is due to your add-in installed, the dependency packages might be out of date or too new that is causing clashes with dynamo. So try and disable addin and see how it goes.
IF THE ISSUE STILL PERSIST AGAIN! then, i got nothing i can do to help you already
I would move them back 1/2 at a time until you find which one is causing the conflict. That add-in will either need an update or you will need to go without it.
Yeah okay. Thanks for replying.
But this only worka with dynamo 1.3, and whatever i do, i see no nodes in dynamo 2.0. (Working in revit 2017 may be thats why?)
