Updated: Help us test the 0.7.5 stable release
We are in the final stages of testing the next stable release, which will be 0.7.5. Please take a few minutes and download this build
Kick the tires, try out your existing workflows, let us know if you see anything bad. Check the readme for details, but this build should clean up the major “known issues” from 0.7.4.
Thanks for any time you have.
-Z
0.7.5 does look very stable - nice! These are the only critical issues I came across:
The 0.7.5 release notes claim that name collisions with packages have been fixed when indeed they haven’t: https://github.com/DynamoDS/Dynamo/issues/3208
Dynamo UV coordinates are no longer being translated to Revit UV coordinates (showstopper for planar and revolved surfaces, as they use a different value range in Revit): https://github.com/DynamoDS/Dynamo/issues/3423
Seems fine to me, doesn’t fix some previously known issues but nothing crashed until now. Is there a risk that some definition can’t run in 0.7.4 when saved in 0.7.5?
Testing the email reply functionality.
Here’s another one - involuntary deletion of objects from the Revit model: https://github.com/DynamoDS/Dynamo/issues/3431
Hey, updated 075 release candidate. The involuntary deletionn of Revit object is fixed, and a few others.
Submitted a Crash report for DynamoReleaseCandidate2Install0.7.5 on github (#3484)
Also, an error with regards to ‘Curve.Extrude…’ (#3483) also applies to this release
Regards,
Vikram Subbaiah
