Hi, i want to update the type name of the window series based on an Excel table I have so that it has - mm x mm Ensure that the width and height retain their original structure
how can i do that?
thanks if you can help me
Post your progress and people will be more likely to help you. I’d suggest trying to split the names up into pieces to get width/height values as a starting point.
Oh hi, I can only upload screenshots because I’m a new user so I can’t share files, I just got stuck at the beginning.
Why are you filtering doors if you want windows? Also try the ‘all family types of category’ node from clockwork instead, it looks like your method doesn’t return anything.
Have you tried importing your excel data and getting family type parameters yet?
oh i was also doing to the door replace also, ok thanks i try to use that
