I have a rather annoying issue with the DynamoPlayer. I designated two inputs as you can see and my module is saved with nothing selected (with orange warning). After exiting Dynamo and saving the Revit file when I run the module direct from the player, it doesn’t come up with edit inputs, but runs through with an earlier set of values I saved with four versions ago! Additionally, if I press the “black cupboard” icon edit inputs, select and enter a values and press play, Dynamo goes ahead and ignores these inputs and executes with the long forgotten defaults…
