Hi all,
I am trying to import data from excel table into Revit properties palette. In fact, my graph runs normally if I only select an element but when I try to match multiple info with multiple element at the same time it just goes all over the place. I’m guessing it is a lacing issue but I tried to work around that for a while now and couldn’t find the way how to solve it properly.
In this case I have getitematindex node which only allows me to select one set of data and it is understandable why it only works with one element but still, I don’t really know which node I should be using to replace that. So, I would like to ask if anyone could help me fixing this. Thank you.
This graph shows when I selected multiple elements
