My graph begins with selecting a model element. The graph will run when using Select Model Element node to select one element.
It does not run when using Select Model Elements.
Is there a way to select multiple elements and then have the graph run one element at a time?
This just means that you have a list structure or lacing issue. We need to see your graph to determine more.
The only way to run an entire function across an element in sequence is to put it into a node or Python script, then instruct the code to work either across each input in Python, or @L1 for the input to the custom node as far as I’m aware. Otherwise it will work across each element node by node.
I ended up saving my working graph as a custom node and placing the ‘Select model elements’ node before the custom node. Thanks for the replies to this thread!
