Unable to open dynamo from revit
Trying to open Dynamo from Revit, but its not Opening.
its showing the Blank Window.
Even i was unable to maximize the Blank Window Even.
The Image attached below of my revit and Dynamo which shown at Task Bar.!
Please help me out!
Thanks in advance!
UNABLE%20TO%20OPEN%20DYNAMO
Have you tried a restart of your computer? It worked for me when I had the same problem.
i have Restarted many times.
i reinstalled my Revit and Dynamo too.
But no Change!
Check your Revit journal and Dynamo logs to see if any hints are there. Then try checking your Revit add-ins and Dynamo packages by removing them all.
dynamoLog_b2661c55-fae8-44fe-83c6-ddbb7024a33a.txt (65.8 KB)
Here’s log file,same issue here.Could you please check it,Thanks in advance.
Updated:
I’ve solved this issue.Incase anybody search for this topic,I tell what I do.
1 Open C:\Users\ YourUserName\AppData\Roaming\Dynamo\Dynamo Revit\2.19 folder
2 Remove all folders to other places
3 Open Revit again and dynamo opens
4 Copy back package folder back
This is strange issue,I never met this before.But this way which may seem not smart but it’s effective.
The post could be closed now.
