Dear All,
I am using Revit 2024 & Dynamo 2.17.
I have downloaded Orchid 2.18 from GitHub (GitHub - erfajo/OrchidForDynamo: This repository contains the content of the Orchid package for Dynamo) & installed in system.
But still orchid package is not available in dynamo.
Any advice/suggestion to resolve this issue.
Thank you.
The Orchid package is supported only via the github for the project as the code is not open sourced and the author is not active here. Submit an issue there.
You should also update your Revit 2024 to the latest point release, 2024.1.1. This includes Dynamo 2.18, which orchid is built for. The current version you have includes 2.17, so his installer will not work on that one.
If you update your Revit, you should be good to go. But beyond that, the Github link is the best support avenue.
Thank you @john_pierson for advice.
I have a similar problem, but am running Dyanamo 2.19.
I installed Orchid using the package manager but the only node visible is the readme node. I then downloaded Orchid_219 Revit.zip file from Github but now the package manager is reporting this error:
Sorry, I now see the comments that I should ask at Github. Will do that, but I’ll leave this up here for now and report back if I have a solution.
