Orchid for Dynamo 2.03 (Revit 2019)
Hi, Is there a way to install orchid on Dynamo 2.03 for Revit 2019? I am unable to find the installer for that version and I am currently working on a project in RVT 2019.
cheers
Hello! This link is expired, could you please update it or somehow send me this version? Also need…
I believe the author now supports 2020 as their lowest build. You could try installing it for 2020 and copying the package files across to your 2.0.3/4 folder though maybe?
The installers are here:
Yes, I’m aware of this, I just thought that maybe the same files for 2019 were saved. I’m not sure that the 2020 version will fit in 2019, because I heard that there are some differences in the API, but I’ll try)
Here it is
Thank you very much! Helped out a lot!
Hi! I am also working in Revit 2019 and could really use the Orchid package. Could someone share the installer through WeTransfer once again?
Thank you in advance!
At this point I’d ask erfajo on his github. This comes up often and would be a cleaner solution vs relying on random people to pass it around.
