Hey forum, i would start by saying, that if i violate some rules, or give a bad description, that i am inexperienced and sorry.
My problem: I am unable to build a cloned repository of Dynamo, found on: https://github.com/DynamoDS/Dynamo. A list of the errors can be found in bottom. Most errors seem to be issues with missing files such as dll’s:
When i try to follow the path, where the dll’s should be, i cant find them, hence i cant recreate the references. Am i missing something here? I only cloned the repos from the git, and tried building it, since i need the dll’s for the Revit Testing Framework.
What i have tried:
Finding the dll’s elsewhere(maybe in another folder)
recopying the repository
reading the README file
Looking for others with same issue, but couldent find any, so maybe im phrasing my issue wrong
I am sorry, that i dont have more information, i am feeling quite stranded with this issue
I did this, and while i did indeed lack the latest package, it did not resolve my issue, as the files are still not present in the respective folders, however i was able to do this in another solution, where i could more easily find the files. After doing this i simply copied it over into the debug folder, and now alot of my errors have subsided. There are however still some meta data missing, which is featured below. I do however see that all the missing data, is being looked for in another folder, than the one i pasted into, so if i continue to lack a delicate approach, i might try and copy into it also.
