TypeError: TypeError: expected Curve, got CurveLoop Building Pad - Dynamo + Python
Hi Everybody.
I´m trying to create a building pad with python node.
pad = BuildingPad.Create(doc,typeId,levelId,loop)
I’m not sure about this error.
Python Script got crash:
File “”, line 38, in
Script:
#Import Revit Services
clr.AddReference (“RevitServices”)
#Import Revit API
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Architecture import *
clr.AddReference(‘RevitAPIUI’)
#Import Revit Node
clr.AddReference(‘RevitNodes’)
#Import Proto Geometry
import System
#inputs
level = UnwrapElement(IN[0])
padType = UnwrapElement(IN[1])
curves = IN[2]
#necessary ID’s
levelId = level.Id
typeId = padType.Id
#creating CurveLoop
loop = CurveLoop()
for c in curves:
loop.Append(c.ToRevitType())
#get the document
#use safe transaction with Revit
#creating pad
loops = [loop]
#Finish transaction with task done
OUT = pad
That method requires a .NET list of curve loops and in IronPython you can instantiate such a list using the following syntax:
loops = List[CurveLoop]()
loops.Add(loop)
pad = BuildingPad.Create(doc,typeId,levelId,loops)
Thanks my friend
