TypeError: expected Curve, got Curve - Dynamo + Python
Hi Everybody.
I´m trying to create a wall with python node.
I’m using " Wall.Create(doc,curve,level.Id,bool)
I’m not sure about this error.
Python Script got crash:
File “”, line 41, in
This is my Script:
#Revit API permite usar elementos de Revit (geometría, líneas, etc)
clr.AddReference(‘RevitAPI’)
#Get Revit Elements
clr.AddReference(‘RevitNodes’)
#Access Revit Document
#Transaction permite ejecutar acciones en Revit
Curve = (IN[0])
level = UnwrapElement(IN[1])
bool = IN[2]
refLines=
if isinstance(Curve, list):
refLines.extend(IN[0])
refLines.append(IN[0])
wall =
for i in refLines:
  wall.append(Wall.Create(doc,refLines[-1+1],level.Id,bool))
OUT = wall
This is a namespace conflict. Both DesignScript (Dynamo) and the Revit API have a Curve class. Judging by what it shown in this blog post, you should be able to take your curve from Dynamo and convert it to a proper Revit object like this:
curves = IN[0]
is_structural = IN[2]
walls = []
for curve_ds in curves:
    curve_rvt = gc.ProtoToRevitCurve.ToRevitType(curve_ds)
    walls.append(Wall.Create(doc, curve_rvt, level.Id, is_structural))
Edit: See @Kulkul’s post for proper syntax.
The error is telling you that you are providing a Dynamo Curve, but it expects an Autodesk.Revit.DB.Curve. It is also good practice to avoid naming variables the same as Python built-in functions or other objects. For example:
bool (Python object)
Curve (Revit and DS class)
Thank you!!
But, when I use your script,I get a new error :S
Help me pls!!!
AttributeError: ‘Curve’ object has no attribute 'ProtoToRevitCurve’
Hi @niojuri22
You need to convert to RevitType() as @cgartland pointed and make sure you import clr.ImportExtensions(Revit.GeometryConversion) in order to use RevitType():
from Revit import GeometryConversion as gc
clr.AddReference('RevitAPI')
import System
curves = IN[0]
walls = []
OUT = walls
Thank You Very Much!!!
It works!
