Hi, I have a problem with creating bulding pad with python. I get all the necessary inputs, but I cannot create an IList with curve loops. So I get the following error: "…line 46, in
TypeError: expected IList[CurveLoop], got CurveLoop". Could you please help me how to write it properly. Here is my script and python code.
Pad_Creation.dyn (9.9 KB)
#Import Revit Services
clr.AddReference (“RevitServices”)
#Import Revit API
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Architecture import *
clr.AddReference(‘RevitAPIUI’)
#Import Revit Node
clr.AddReference(‘RevitNodes’)
#Import Proto Geometry
import System
#inputs
level = UnwrapElement(IN[0])
padType = UnwrapElement(IN[1])
curves = IN[2]
#necessary ID’s
levelId = level.Id
typeId = padType.Id
#creating CurveLoop
loop = CurveLoop()
for c in curves:
loop.Append(c.ToRevitType())
#get the document
#use safe transaction with Revit
#creating pad
pad = BuildingPad.Create(doc,typeId,levelId,loop)
#Finish transaction with task done
OUT = pad
