I’m trying to learn how to create nodes, from python, following the references to posts that were previously made, why the error?
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Structure import*
from System.Collections.Generic import IList, List
# dynamo curves as input
curves = UnwrapElement(IN[0])
rebar_style = UnwrapElement(IN[1])
rebar_bar_type = UnwrapElement(IN[2])
start_hook_type = UnwrapElement(IN[3])
end_hook_type = UnwrapElement(IN[4])
start_hook_orientation = IN[5]
end_hook_orientation = IN[6]
host_element = UnwrapElement(IN[7])
vector = IN[8]
def CreateRebarFromCurve(curves, rebar_style, rebar_bar_type, start_hook_type, end_hook_type, start_hook_orientation, end_hook_orientation, host_element, vector):
rebars = []
for c, v in zip(curves, vector):
curv = List[Curve]()
curv.Add(c.ToRevitType())
rebar = Rebar.CreateFromCurves(doc, rebar_style, rebar_bar_type, start_hook_type, end_hook_type, host_element, v.ToRevitType(), curv, start_hook_orientation, end_hook_orientation, True, False)
rebars.append(rebar)
return rebars
OUT = CreateRebarFromCurve(curves, rebar_style, rebar_bar_type, start_hook_type, end_hook_type, start_hook_orientation, end_hook_orientation, host_element, vector)
Hi
the error indicates that you are trying to iterate on a non-iterable object
Check that curves and vector are input lists of the same size
or
just use a for-loop (instead zip() )on the curves object and use vector (type conversion to be done) directly in the Rebar.CreateFromCurves() method.
I’ve checked the list curve, right
rebar Python.dyn.rvt (7.5 MB)
Rebar Python.dyn (27.0 KB)
Good morning
you are missing:
import System
in your code
Sincerely
christian.stan
you must analyze the error message, in this example there is a problem with several object types passed as arguments that do not match with the Revit API.
here the fixed code
import sys
import System
rebar_style = System.Enum.Parse(RebarStyle, IN[1])
start_hook_orientation = System.Enum.Parse(RebarHookOrientation, IN[5])
end_hook_orientation = System.Enum.Parse(RebarHookOrientation, IN[6])
vector = IN[8]
rebars = []
rebar_style,
rebar_bar_type,
start_hook_type,
end_hook_type,
host_element,
v.ToRevitType(),
curv,
True,
False)
return rebars
It turns out that the string must be converted, yes, I think at the beginning he can read string data ,
Sorry mr, I tried again, by create a rebar curve stirrup, showing an EOF error, but I tried to make the standard rebar successful, why?
ikhsan.pc:
check the end of your script, missing parenthesis or missing quotes
@c.poupin Hi,
I’m using the script above you’ve fixed to model stirrupties. After running the script gives the following error: CreateRebarFromCurve TypeError: expected Curve, got CurveLoop.
Could the cause be that I’m feeding this script with rectangles (as curves). The startpoint is the same as the endpoint so that could be the CurveLoop.
Try to get the longest curve.
for curve_Loop, v in zip(curve_Loops, vector):
max_curve = max(curve_Loop, key = lambda x : x.Length)
curv = List[Curve]([max_curve ])
This triggered a new error:
File “”, line 58, in
File “”, line 40, in CreateRebarFromCurve
TypeError: Error in IEnumeratorOfTWrapper.Current. Could not cast: Autodesk.Revit.DB.Curve in Autodesk.DesignScript.Geometry.PolyCurve
I’m still trying to find out how to post my Python script as you guys do. Feel a bit stupid now…
@d.kelfkens
Paste your code, select it, then click this button.
import sys
import System
#vector = IN[8]
vector = UnwrapElement(IN[8])
rebars = []
max_curve = max(curves, key = lambda x : x.Length)
#curv = List[Curve]()
curv = List[Curve]([max_curve])
rebar_style,
rebar_bar_type,
start_hook_type,
end_hook_type,
host_element,
v.ToRevitType(),
curv,
True,
False)
return rebars
This means that you have an object of type Dynamo PolyCurve instead of a Revit CurveLoop object as you mentioned above.
you must convert Dynamo Geometry to a Revit GeometryObject, read this
Try this (untested):
import sys
import System
polycurves = IN[0] # assume is a list of polycurve
#vector = IN[8]
vectors = IN[8]
def CreateRebarFromCurve(polycurves, rebar_style, rebar_bar_type, start_hook_type, end_hook_type, start_hook_orientation, end_hook_orientation, host_element, vector):
rebars = []
for polycurve, v in zip(polycurves, vectors):
max_curve = max(polycurve.Curves(), key = lambda x : x.Length) # we get only the longuest curve
curv = List[Curve]([max_curve.ToRevitType()])
rebar_style,
rebar_bar_type,
start_hook_type,
end_hook_type,
host_element,
v.ToRevitType(),
curv,
True,
False)
return rebars
OUT = CreateRebarFromCurve(polycurves, rebar_style, rebar_bar_type, start_hook_type, end_hook_type, start_hook_orientation, end_hook_orientation, host_element, vector)
My input. Maybe I’m doing something wrong.
Yes, in your case, you need to pass arguments (all input lists) to the zip function.
The Python interpreter has a number of functions and types built into it that are always available. They are listed here in alphabetical order.,,,, Built-in Functions,,, A, abs(), aiter(), all(), a...
