I’m working on a dynamo script that can automatically find the shortest path(Topology) between two racks on given cable tray pathway. I was lucky, the development process is really smooth.
But Im stuck at the last step, I’m looking for a method or a node that can turn the curves into one conduit(Curves as shown in snap)
Output is a shortest pathway (polycurve) from topology. Ideally, the plan is I deconstruct the polycurve to get these lines and turn lines into conduits.
However, The result from that script is a bunch of segment of conduits, its still look like a conduit run(fully aligned), but its not connected and without fitting.
There are direction I thought but cannot move forward:
- Merge the line, then turn into conduit , then create fitting by MEPover. But I don’t know how to merge the curves to line.
Thank you in advance, I appreciate any help or idea.
