Trying dynamo in AutoCAD to make advanced tasks
Hello every one first I work in AutoCAD and I hope that dynamo work in it …
I have some ideas and I need to know if it can be real or not by dynamo or programming …
I need to insert blocks sizes according to spacing between other blocks …
if I can make that there is more and more cases and details that I’ll learn dynamo to make what i need …
I can’t upload this DWG or even media here because the website terms… if you want to help me please contact me in my mail
Mostafa.hisham62 at gmail dot com
and thanks in advance …
Hi
See this is
And
Translated by moderator. See below the line for original post.
Thank you, engineer.
Could you please explain further?
Original post below
شكرا يا هندسه
ممكن توضيح اكتر من حضرتك ؟؟
@mostafa.hisham62 the language on the forum is English, which sadly is a requirement for search to work (annars skulle jag öva min svenska).
Please translate future posts using the translation tool of your choice, optionally leaving your original native language post separate from the translation as I did in the edit to your post above.
Just for clarity Dynamo does not natively work in Autocad, though if you use Civil 3d then you will be able to use and have access to Dynamo.
One just to watch out for and thought i would indicate as a FYI
