Hello , everyone! Any expert in dynamo has the solution for the Curved.ShortestWalk from LunchBox, I have noticed an issue with this and not functioning. Thank you
Lunchbox isn’t supported and should be removed from your production environment.
Topologic has a better performing option. And VASA can identify traversable paths without having to build a curve network.
Hi, is this two option can work as the shortestpath nodes?
Yes, both VASA and Topologic can do the work; the question is the context in which you are trying to use it, which we don’t know as you have only posted about a node from a package which was abandoned over 4 years ago not working anymore.
