Hi guys,
When following @Dieter_Vermeulen tutorial upon how to use the node “Curves.ShortestWalk” from the Lunchbox package i get this message:
*Warning: Curves.ShortestWalk operation failed. *
Method not found: ‘Autodesk.DesignScript.Geometry.PolyCurve Autodesk.DesignScript.Geometry.PolyCurve.ByJoinedCurves(System.Collections.Generic.IEnumerable`1<Autodesk.DesignScript.Geometry.Curve>, Double)’.
Any ideas why this is happening?
First I did it in Dynamo 2.0, but i did not work… For troubleshooting I created it in Dynamo 1.3, it seemed to work for others on the forum, but I can’t figure it out…
@Dieter_Vermeulen did the tutorial in Revit 2017, but i have Revit 2018. Could this be the issue?
I hope some of you have the time to help
Thanks in advance!
