Top FaceType value ClockWork
Hi everybody. I have a problem when using node clockwork it doesn’t show the top facetype value. hope everyone can help.Thank you everyonetop facetype
Hello @vannam.94 ,
I think this Node is not considering ceiling, as a top of bottom surface, only floor elements are considered.
Once you close your room with floor elements it will show you top and bottom surface.
Check your room’s upper limit. If your floors are not in room range, they won’t be taken.
thank you. can you guide me how to get the ceiling object in the room
Hello @vannam.94 ,
If you wanna get ceiling present in a room, then you can follow this concept.
Room Ceiling.dyn (21.1 KB)
In this script, I am only concentrating on ceiling because you already know how to get walls and floor of the rooms.
Hi …another way…
