Tool to find the version info about any node in a Dynamo graph
Is there any tool in Dynamo for Revit to find the version info and package info for any node in Dynamo?
The monocle view extension is useful for this. And starting with Dynamo 2.5 there is a Dynamo Workspace References extension built in.
Thanks for the response. Turns out I was using older version of Monocle.
Just a quick question, as I use Dynamo 1.3.4 and 2.0.1, how would I know which latest version of the Monocle package should work for me for each version of Dynamo?
The best fix here is to update to 2.0.3 for Revit 2017, 2018, and 2019. Then go for the latest version and see if it works in 2017. 2020 and up will self control Dynamo updates and you’ll want to check your packages and view extensions on Revit updates.
